1940 ford
mikeyjoe
detroit
MI
Price
$10,000
005.jpg1940 ford coupe (NO MOTOR AND NO TRANS) good project the primer that is on it was put on in the early 1960's please call mike 734 365 1269 $10,000 HAVE TITLE THE CAR SAT IN THE SAME GARAGE SINCE 1963 UP UNTIL 2 YEARS AGO. INTERESTING TRADES DONT BE SHY YOU NEVER KNOW
unfortunately it has the 40 front end and not the 39. Do you know if they can be easily swapped?
Front fenders are "almost" the same from 39 Delux and 40 standard are the closest, with the 40 Delux having a slight difference. To make a 40 Delux a standard you would need the 40 Std or 39 Delux hood and the 39 Delux or 40 std grille (the 39 Delux being more expensive with more chrome), mounting pcs, and chin pan. I believe everything 40 Delux will work from there ...
The dash is very different from the 39 delux to 40, and the 40 Std dash is different than the 40 Delux via different gauge clusters and a bit more chrome on the dash of the Delux.
Others will chime in I'm sure to give you more info ....
Love the body style... hate the front end grille...thanks for the info
