wspiker
It appears to me that the process is to remove the radio nut from the top of the radio, raise the radio up under the dash and line-up the hole for radio nut with the hole where roof mounted antenna is located. At that point, screw the radio nut into the spot where it was removed, as this nut will hold the radio in place by suspending it from the dash. I assume this is correct? In doing this, it appears that a hex-head from the radio nut will be visible on the dash and will not be covered by the antenna hold down nut. Is this correct?
Thanks,
Thanks,
