markivpedalpusher
When I purchased my truck there was no key to the passenger door lock. I picked up a vintique repop door lock assembly and possibly an NOS or older after market door lock with Yale keys. I would like to install the lock with the Yale keys. But there is the problem. The set screw that holds the lock in is missing and the set screw hole is about the size of a dime which means at some point the set screw hole has been jacked up and over sized. So my question is does anyone have any ideas of how to get the lock assembly to stay in the door? The access hole to where the set screw should be is too small to take a picture. I could use an adhesive in the lock cylinder hole but I'm apprehensive to install it like that. If anyone has installed these locks you know the set screw side is not accessible to modify at least from what I can see.
Any advice is appreciated.
Thanks
Thanks
