Kube can you help on this question? Thanks!
I have never been able to find any clear documentation that would offer a positive explanation for the numbers referred to in this post. To clarify, that is when we find them (numbers) on
closed cars. It appears there was never a production order to stamp these cowls (dash panels) when installed in to closed bodies.
Why some closed cars got this treatment while others did not is, at this time, still a question that deserves a definitive answer.
On wagons and convertibles, there was in fact a production order to number the bodies. However, here too it is a bit perplexing as two distinct ways to number the bodies was obviously employed. Most commonly it seems, a small tin tag with the sequential body number was nailed to the dash panel at the very upper left corner; a bit above the regulator - upon the vertical area...
It is only my opinion at this point that the tag was the intended way to number the bodies as the dash panel had dimples pressed in that area to locate the tag. Should the dash be destined to a convertible or wagon, these dimples would have been drilled out to accept the nails.
Sorry guys, I can't offer a better explanation at this time. Any one hanging out there with
proof ... PLEASE share it.
