tweetiebirdcenter
So I replaced my headlight switch on my 40' coupe and I installed the knob now it is upside down. Instead of an L for lights now I have a 7 which way do I have to turn the knob so it is correct?
I had this problem with a new light switch knob with an upside-down L. I was not able to just rotate the switch 180 degrees to solve the problem. This was back 2016 so I can't remember why not....perhaps the original wires would not reach if rotated?The knob on the switch will only work in one position. You need to turn the switch 180 degrees on the back side of the dash. Then it will be an L. Good luck
