1940 ford gauge cluster
Deucenut
Does anyone know if there is a reproduced 1940 ford instrument cluster that is 12 Volt? Or am I stuck looking for an original to convert? Thanks in advance for the help
Thankyou for the replies. I meant a stock original repro dash that is 12V. Anyone make those? I'm not too fond of the classic instruments one
Here's one for sale. Also, check Ebay.
http://www.fordbarn.com/forum/showthread.php?t=90865&highlight=1940+gauge+cluster
Buy it and have it converted to 12V.
Some good reading:
http://www.fordbarn.com/forum/showthread.php?t=162519&highlight=12V+gauge+cluster+conversion
http://www.fordbarn.com/forum/showthread.php?t=201394&highlight=BATT+gauge+12V&page=2
My solution is posted in #8 response here. I still am using the OEM gas tank fuel sending unit since 12V units don't work with the OEM FUEL gauge. However, i suppose it would be possible to get this this converted to operate on 12 volts so it would work using a modern 12v fuel tank sending unit.
http://www.fordbarn.com/forum/showthread.php?t=182651&highlight=1940+BATT
Here's a modern 1940 Ford "STYLE" gauge cluster.
http://www.speedwaymotors.com/Class...Ford-Original-Style-Gauge-Cluster,112215.html
You must read this thread. http://www.jalopyjournal.com/forum/threads/40-ford-dash-guage-cluster-dont-like-mine.805408/ and
http://fordbarn.com/forum/showthread.php?t=48622
I live 30 miles from Classic and was there this past Summer. Yes they do make a '40 cluster, but .......$$$$$$ very expensive. The one they showed me was for a '40 Standard and was $750. It was 12v.......and they had included a Tach in it too which really looked bad ***. They really do nice work.
Convert it yourself. Use some L7806 for gas, oil, and temp gauges and a 60ohm resistor for the Battery gauge. I did mine in my '40 for about $5 total.
You can use the 6 volt gauges with a Ford Instrument Voltage regulator as used in 1957 and later.
