Just had my 40 Ford standard gauges converted to 12v by Lee Kelly, who probably has done thousand of them, and he recommended the replacement sending unit 99A-9275 available from Carpenter, Drake and Yogi's. Got one from Carpenter; the ohm bench testing showed the sending unit was sending a reverse signal...full vs empty.
Double checked with Lee Kelly who said the unit did appear to send in reverse so I then called Carpenter and here is the response I got. I was told to send it back for credit and that they would not exchange it nor send me another unit even if I chose to buy another. There was no willingness to discuss the problem, the extent of the issue or defect which suggested to me that this is pervasive product problem which Carpenter attributes to the customer's ignorance or lack or knowledge. From Carpenter, this really surprised me. Not sure where to go at this point.
