That may be true if one is attempting to duplicate original factor installation, but functionally it doesn't matter.I suggest there is a front and rear .any stamping information or embossed lettering that is found on the boss of the axle close to the one end ,the axle should be placed with the embossed lettering to the right front.
The definitive answer.Actually, there is a front and back. Once you get the axle installed, get down low, directly in front of the car and look at the axle. The side you can see from that angle is the front.
I agree.all that there is no difference with a new axle ,however from factory I suggest that the axle was installed with the Ford stamp and part #,facing the front [right side] Where one should be careful is when restoring a car,taking the front end apart: one could install the axle reversed as it is quite likely that some time in the cars life an attempt was made to bend the axle ends to correct an alignment problem putting it in reversed would create a bad steering condition.
Difficulty in fitting the kingpin cotter pins in is probably real. Mart.
