WRA Senior Member Dec 27, 2023 #1 Folks, I have a 1940 Deluxe coupe. The drivers side window has suddenly decided that it won’t roll down past the 1/2 way point. Previously worked fine. Any tips or trick of what to look for before I pull it apart. Thanks.
glennpm Well-known member Dec 27, 2023 #2 You may have a couple of stripped teeth in the window regulator.
TJ Well-known member Dec 27, 2023 #3 You'll need to pull the door panel do see the problem. There are several possibilities, but pulling the door panel will tell you what went wrong.
