C classiclover Junior Member Nov 9, 2021 #1 Anyone advise me on proper way to remove outside door handle on 1940 ford coupe Thks Dale
51 MERC-CT Well-known member Nov 9, 2021 #2 It's been over 50 years since I owned a '40 Ford but as I recall there is a screw just inside the door edge that goes in at a 45 deg. angle.
geoford41 Senior Member Nov 9, 2021 #4 That is correct just remove the screw and pull the handle out it maym be rusted so it could require a little force.
