Terry I had taken that off to get to spring,so are you saying this set-up is wrong?Can I just switch them around?Long brake shoe to the front, also larger size brake cylinder to the front. Looks like photo is missing the link for the hand brake from the rear lever to the front shoe.
shoes around the wrong way will give you low stopping power & high wear as the short lining is doing most of the heavy lifting
The answer to that question is explained by deuce roadster in Post #12 here:
https://fordbarn.com/forum/showthread.php?t=245506
and here
https://p15-d24.com/topic/57524-why-were-the-rear-brake-shoe-linings-shorter-on-lockheed-brakes/
On a stock 1940 Ford,can someone please tell me on the brake shoes does the long shoe go in front or back on backing plate?I am getting mixed info on this.I presume they are Lockheed brakes?here is photo of what I have now.This is drivers side rear.
