yngrodder
- City
- Taylorville
- State
- Il
- Price
- 2500.00
1940 ford 2 door sedan LOWER PRICE!!
1940 Ford 2 door sedan project, Chassis is all stock Flathead with 3 speed trans Org Hyd brakes, Flathead turns over but does not have dist, carb and fuel pump will need these to make engine run, Body has been blasted and the main body has been put in primer the doors fenders and hood are still bare metal, Body needs rear panel under trunk replaced, a few patchs in floor, Quarter patch panels (one side has already been welded in but needs finished) New patch panels for the quarters and the area under trunk included with car, the rear fenders will need some patching work done where the bolt to the body, Has Dash, Steering column,Garnish Mouldings, Seats (Needs redone) A couple door hinges need replaced as well, Has a clean Title,
