Kube, my end game is to restore it to nice driver car show truck.It certainly deserves a frame off.The motor is a 49.its almost rust free but does have issues with the bed fwd corners and pass cab corner
Okay, thanks for the clarification.
I disassemble every vehicle at one time down to the last nut and bolt. To this day, I still take photos. If this is your first restoration, I'd suggest you take a LOT of photos. Don't leave anything to memory.
Label anything that is not self evident as to what it is.
Keep the fasteners securely with the respective part they came from.
I would suggest you take a good inventory of anything and everything you may need to put this vehicle back together. Then, and as soon as possible, begin acquiring those pieces. Do NOT wait until you need them.
When the vehicle is completely disassembled and to keep you motivated (it can get overwhelming at times) you can move to a different subassembly should the one you are currently working on get too frustrating at the moment or you simply need a piece to keep that part moving forward.
Having another assembly to work on may help you in a couple of ways. As I'd mentioned, it will keep you motivated as even though one assembly is momentarily on hold, you can see another moving forward. Progress induces the desire for more progress.
Also, when you get toward the final assembly, it is very rewarding to have all of the subassemblies done and all you need to is gather them.
I tend to ship out any work I am unable to do promptly. I no longer have access to the requisite machines to rebuild an engine so the engine gets sent out right away.
Need new glass? Get it to the local shop now.
The bottom line here is you don't want to be held up by some clown that promised "two months and it'll be done". Many of these guys operate in a different dimension where "two months" can mean anything from two months to three years.
By the time I have my body and paint done, my chassis is ready to place the fresh body down. Also, each and every part (sans the inevitable piece or two I'd overlooked) is in a box, cataloged and ready for me to simply grab and install.
That's my basic take on things. As you may have read in to my advice, I worry about folks that are new to this and have offered my advice with an underlying sense to maintain your enthusiasm. Many, many of them started with the best intentions and got little further than the disassembly.
I have looked at and purchased many of these projects that have sat for, in some cases, decades.
