Karl Wescott
With due respect to all,
It appears to me that there is also an uneven gap door to cowl. Presuming this is not caused by an improper dovetail it can be adjusted by bending the lower hinge forward. As the gaps are complementing it should help with the too tight gap at the bottom of the "B" pillar and drop the top of the door to be more in alignment with the top of the quarter.
When putting things back together remember Ford had "offset" dovetails to accommodate slight vertical alignment differences with the dovetail and door socket.
