1940 dashboard
Ken hash
30482E00-12EC-4BD3-A0BE-C27E758656D5.jpg This is my attempt to show a picture of the dash board on our coupe.
I tend to agree in that Gregorie got it right the first time.
Thanks, the process is two colors of paint then clear. I used water base ppg. The first color is very light tan. Let it dry then spray a coat of dark walnut brown over the tan. While it is wet, lay a plastic shopping bag directly on the wet paint, then lift it off. Repeat the plastic bag application until you like it. I started with a sample part. With water base paint you can clean off the dark paint before it dries and try again.
What are your plans for the window garnish moldings, the same grain or a contrasting color?
Sounds like a good graining technique.
Here are some photos of the garnish molding
When someone restored my convertible in the '70's they painted the dash woodgrain. It reminds me of an old console radio.
Kube: Were they also available for both sides on a standard as mine has both.
Ya know, that was something I could find no documentation on while doing my research.
While common sense might suggest they were optional, if you're seeking points on a judged concourse, I'd suggest you do not install them.
