adavis
I pulled the front drums off last night. The shoes are basically new as well as the wheel cylinders but the drums have some grooves. The shoes dont appear to have been "arched" to match the drums as there only looks to be contact at either end of each shoe.
I have a pair of nice late style heavy drums that look excellent. I dropped them off at the local shop this morning to be cleaned and trued. I had to order new seals so I'll get them installed next week. I'm also going to sand the shoes to match the drums once I get them back.
When I adjusted the brakes I first loosened the outer nuts on the lower adjusters then spun the wheel and turned one adjuster till it drug, then backed off till it was just free. I did the same to the other lower adjuster and then tightened both nuts. The I moved to the two upper adjusters (eccentrics?). I spun the wheel and turned each adjuster until it drug then backed off slightly. If this is not the correct procedure feel free to let me know.
I'm using plain old DOT3 brake fluid. I have new speed bleeders installed on all corners and have ran fluid through each wheel until there are no bubbles....and then ran more fluid just to be sure.
Thanks again for all the input. I still can't believe that brake adjustment would be the culprit to my brake pumping dilemma, but I'm going through everything and learning while I do it. I'll keep you posted on the outcome.....
Sent from my SM-G960U using Tapatalk
