1940 4 door
tom0811
New member
chicago
illinois
Price
10K OBO
FOR SALE
1940 FORD FORDOR​
Frame cleaned and painted with POR-15
Ÿ body was not removed from frame
Completely rebuilt brake system
Ÿ cast iron drums
Ÿ new wheel cylinders
Ÿ new pads
Ÿ new master cylinder
Ÿ new brake lines
Ÿ new springs and hardware
Ÿ new emergency brake
Completely rebuilt drivetrain
Ÿ rebuilt engine including modified lift cam, large ss valves, new oil pump and water pumps, gm alternator, offy aluminum heads, Vern Tardel split intake, new headers, electronic ignition, rebuilt carbs
Ÿ new clutch and flywheel
Ÿ rebuilt top load 3 speed transmission
Ÿ new u joint
Ÿ completely rebuilt rear end with new 3:54 ring and pinion, bearings and seals, shock mounts welded on rear
New wheel bearings and seals
New plastic gas tank and sending unit, electric fuel pump in rear, regulator and gauge at fuel block under hood
5 new Coker bias plys on powder coated rims with hub caps and trim rings
New springs front and rear. Fronts are reverse eye for drop
Rebuilt steering
New Walker radiator with ss tubes
New 20 fuse ‘IT’S A SNAP’ wiring harness
Body stripped, primed, and painted using minimal bondo. Floors are solid
SS deluxe body trim and outside door handles
Be Bops fiberglass front and rear fenders with USMC pinstriping
All doors and trunk close and open well
New grey tinted glass
Ÿ all glass set in new rubber
Ÿ new tracks with rebuilt regulators working great
Front and back seats done (see pics)
LeBaron Bonney interior panels. Complete set/unfinished
Front fenders, hood, and grill not fully installed/aligned
Some minor paint damage(scratches and small chips)
One small weld on passenger side of hood popped(see pics)
This car has a clear Illinois title. Receipts for motor rebuild, paint and body, and parts. Many extra parts ( see pics)
Check out more pictures (link below)
http://s86.beta.photobucket.com/user/redheaddevil/library/
Selling price is $10,000 OBO
Please contact me:
TWMulvenna@sbcglobal.net
(847) 312-2523
