Looks like it does only at the bolt hole.
Not a critical area, but take care while mounting to the block, torque this bolt last.
Alan and Mike,
Your responses strike me as out of character.![]()
I was wondering how long it would be until someone would note that.
David, my car? And if I had another case? I'd use the other case.
You got me![]()
Whew! Sleep will come easier tonight. The earth is still spinning on it's axis!
You got me![]()
Nope, I don't buy that. Mike would V it out, weld it, grind it, sand it, fill it, prime it, wet sand it, prime it again, ad infinitum.
If I didn't have another case perhaps. Okay, YES, I would do just as you figured.
Man, I can't get away with anything around here.
I will keep tryin' though...
When you get old and bald like me, I’m quite sure you’ll then wet sand your noggin and use carnuba on it.
