1939 pickup hood latch assembly question
Seth Swoboda
Can someone please post pictures of how the hood latch/ornament is assembled on a 39 pickup? I have pieced my hood ornament/latch together from parts I have gathered from ford barners.
Thanks, Seth
Seth when I get through today, will post some pic's of my pre-restoration hood area it may help @ quick glance it look's like you got all the part's except the center spring:D
Here is a shot looking at the back side of an installed hood release. May not show the detail you need, though:
Here are some pic's of the hood latch when I pulled the hood and the pieces taken today on my bench:D John that is a great shot that shows the middle rotator piece that I have on the hood latch.
thanks. I cleaned the parts and reassembled the handle. still locked in the side ways position to the left. Mistakenly I cleaned all the parts forgetting which side is up. There was a slight bit of damage where the edges of the square hole rubbed the base of the boxed section of the shaft: thus I put that up. The rub bar sees OK. The bolts holding it on appeared rusted In place. I see no reason to remove it. What next?
Stay safe and strong
Clem you have to close the hood to be able to turn the handle back.
The knub on the radiator that the disc locks to, also pushes up the "pivot lock plate" to release the locking tabs.
Try pushing where the radiator receiver (knub) would hit and turn the handle at the same time.
Use a screwdriver not your finger. If you use a finger, turn the handle slowly or you'll pinch the heck out of your finger. Only has to be depressed for about 10degrees turn of the handle.
Back at it.
It seems to me someone had a diagram of how the latch goes together. I've looked in my threads and don't see it. Bruce is coming by tomorrow to give assembly as try.
Thanks
Here's a couple of photos of my latch.
I need to paint my hood. When I remove the latch again I will take lots of photos. No promises on timelines. I used to have pictures of assemble before. That was a while back. I usually take things apart, take pictures, and put it back.
Maybe these will help. If you want higher resolution versions PM me an email address and I will send the originals.
My Friend Bruce Metcalf made a visit here today before the storm. We find that the shaft with the bolt on the on the bottom wobbles in its mounting. It looks like it doesn't allow the edge of the disk to get in position We used one of the photos you guys provided to be sure the disk was right-side up. Thanks Bruce. Golly that was a fun flogging an old Ford. Someone have an extra disk, please. Thanks for all your advise on this challenge. At the moment I have a matching-color bungee holding the hood nose down in place.
I've got some left over parts from when I put the one on my'39. I'll check tomorrow.
Good luck there Clem...the real sad part about this post is i still do not have that hood latch assembly on my hood yet:eek:
Seeing this post may spark some motivation.
