1939 Pickup E brake line and Speedo cable routing.
Shampipple
I’m trying to finish up routing of the cables for the Speedo and the front e brake cable.
I also purchased a Speedometer cable bracket.
Do any of you have any routing locations, and where does the bracket go?
Shampipple Sorry I can’t help you but maybe you can help me. I have a 39 3/4 or 1 ton I can’t find a front e brake cable. Truck has the floor e brake cable not the under dash. Can you tell me where you bought your cable? Part #. Mine needs to be about 36” long with both ends threaded.
Thanks John
Mine is a 1/2 ton with the dash mounted e brake. I do have a heavy truck trans with the e brake on it in my garage, but it works the drum on the back of the transmission.
