sunnyorm
- City
- tehachapi
- State
- ca
- Price
- 1.
For Sale on ebay
1936 Lincoln Zepher (gears not Zepher) transmission case w/ 1939 Synchro Gearing
Cluster Gear Teeth are 28,24,18,14
Low/Reverse Teeth 29
2nd Gear Teeth 22
Reverse Idler Teeth 18
Hub for Synchro 81A-7105 39-48
Blocking Ring 39-60
Assembly 01A-7124-A 01A Type Synchronizer Hub w/ 3 Ball/ Spring and Plates
6 Spline Mainshaft , center of shaft is measures 2.913
81A-7061 (9.9 L) w/ Pin to engage Thrust Washer
Apart and Cleaned
Some pitting, 1 small piece broken off idler, but main part of tooth still good.
Also: 3 Towers go with it (2 car and 1 truck type) 3" Forks, 1 Stick only
Here's the ebay address:
http://cgi.ebay.com/ebaymotors/ws/e...581862661&viewitem=&sspagename=STRK:MESELX:IT
2nd Gear Teeth 22
Blocking Ring 39-60
Apart and Cleaned
