COE Dan
Hello,
I have a '39 Ford with everything stock. I'm having intermittent ignition problems. When the engine is cold, it starts nicely. When hot, the battery is more likely to run down cranking rather than start the engine. In this condition, it appears I get zero spark. I've traced the wiring and being new appears to be connected correctly. What I did discover is that there are 2 ignition resistors mounted on stock fuse panels in the car.
Only one resistor is hooked up, the other is just there. I've checked the resistance and they are different. The one in the circuit is 4.9 ohms; the other is 8.3 ohms. Which one is correct?
Secondly, the battery registers 6.21V at the battery. At the battery side of the ignition resistor, I'm measuring 5.89V. Is this normal voltage loss to the resistor or do I have a voltage drain somewhere upcurrent from the resistor?
Anything will help, Dan
