Dan39Deluxe
Hey guys,
The car will fire right up off a cold start, switch off the choke, it will idle down and run great for a min, then it starts to starve for fuel or get flooded.
We've rebuilt the carburetor, made sure everything was clean, and the float has fuel in it every time we check (not positive the float is set perfectly but the fuel line rests just below the accelerator pump rod hole when you take the float out
