Like the other guys, I think it has to do with either the master cylinder or the flex line - because of the brake lights. However, if all that fails, then try backing off on the parking brake cable adjustment yoke. That was my fix.
One time I had my shoes relined and I could hardly even get the rear drums back on. Then they would drag like heck. The calipers told me the lining thickness was right. Helpful guys here offered various advice: grind the new lining, turn the drums, shorten the horizontal link between each shoe, replace wheel cylinders, drive it 60mph for an hour to wear in the shoes - when it stops smoking it will be fine, get drunk and go inside the house and forget about it for a while..... Well, I tried it all.
When I got out of AA rehab, an old buddy of mine came over and said, "Loosen up on the parking brake cable." Says I, "I don't think that's the problem; since it wasn't a problem before the shoes were relined." (The shoes were relined not because of wear, but because of leaking wheel cylinders.) He said, "OK. I'm going to crawl under and back off on the cable myself then. Then try to install the drums. EUREKA! He was absolutely correct. Thank heavens I did not do some of the other well meaning recomendations. Take your time. Don't do anything drastic. Two heads are better than one. Explore each recomendation carefully and logically......
Mike
