Need some help - trying to remove the passenger front door glass for replacement. Removed the panel, removed the crank stop but the window doesn't go low enough to remove the arms from the channel. Any help would be appreciated.
You must remove the screws that hold the regulator in place. Lower the entire "thing" to the bottom of the door.
Perhaps I shouldn't say "you must". However, I have done MANY and that method has worked well for me.
