fleetpaint
The Brakes on my sedan are very spongy! I have replaced shoes, hardware, changed fluid, & bleed them 3 times. No air in the lines. Could the master cylinder be bad without leaking?
good advise!...will try that next!....thanks!to check for weak hoses have someone apply the brakes while you are holding the hose (S). If they are bad they will "grow" in your hand. Adjust the master cylinder till you have about 3/4" play in the pedal before it moves the piston
Some times it is difficult!! Did you arc grind the shoes? If so, and all the air is out you have an adjustment problem.I have centered & adjusted brakes. It cant be this difficult?
i adjusted the brakes so the wheels wont turn, still low & super soft pedal?
