Ford Freak
Hey guys ! What is the oil capacity of a '39-'40 221 ci. ,24 stud , 85 hp . engine ?
It has no oil filter . Thanks in advance - FF
I have been running Mobil 1 15/50 in my '51 with the original engine for the last few years (I had a couple of cases left over from a previous racing adventure). I have been quite satisfied with it over that time. It didn't seem to leak any more than conventional oil, and has the added advantage of over 1200 ppm of zinc (although that's really not that important for a flathead). The only drawback is the cost.I was thinking of running synthetic in my '40. New vehicle to me but flattie was rebuilt a while back. I was thinking of Mobil 1.
Phil Swanson
Phil Swanson
Alot depends on how many miles you put on and how often you want change it. I think the cost and change interval is a factor. I've read with interest all the threads on oil capacity. I have an original glove box booklet that says 4 qts, 5 with a filter. It just so happens that 4 1/2 qts puts my 8BA at the full line..... thats my story and I'm sticking to it....... Mark
I think you may be adding some confusion to the subject here.
Your engine is NOT 1939 - 40 - that which is being discussed within this thread.
I found a chart Ford published showing the dimensions of the dip sticks. 48-6750 is the 85 & 95HP dip stick for 35-48 passenger cars. From the stop collar to the full line 11-23/32", from full to low 1-13/32", low to the end of the stick 23/32". Over all 16-5/8" long.
You also want to measure the over all length of the dip stick tube. You have to unscrew it from the boss on the oil pan. BE CAREFUL The boss is easy to brake and is white metal, or just take an approximate length without removing. 48-6754-B is 8-21/64" long.
