1938 Tonner Pedal Linkage questions
DetroitMotion
Can anyone help me with some details or photos to locate where the stop switch and chain(if applicable) are supposed to be located on a 1-ton 1938 truck with cable brakes? I have found info on the pass cars and 1/2 tons but nothing for big trucks.
Also looking for the correct length and location to hook the clutch pedal return spring on the chassis of the same 1-ton truck. I've seen the short spring direct to the close crossmember and I've seen springs that pass through 1 crossmember to hook to the second.
Getting really close now!Thanks.
I don't know if this will help but in the green parts book under the stop light switch
the next item is bolt #24324-S7. It states Bolt (stop light switch to pedal bracket).
So maybe the switch is bolted to the bracket.
Bob
Bob
POSSIBLY(?) like this picture? DD
292701
That doesn't look like my pedal arm bracket but it at least gives me a place to start. Thank you!
I believe the big trucks may have had them attached to the side of the transmission. Does anyone have a photo of that part? Or a photo of your big truck transmission?
