1938 Ford Tudor
Mo$4Ford
New member
San Bernardino
CA
Price
25,000
Car is a Better than Damn Nice Driver.
Well taken care of
What the Car has:
*24 Stud Flathead
*Original 3 Speed
*Torque Tube / closed driveline
*Banjo rearend
*1939 Juice Brakes with New Master
*Bias Ply Firestone 6.00x16 Wide Whites
*Wide 5 4x16 Rims with Deluxe Caps and Rings
*Updated 12 Volt
*New Cloth covered GM Wiring
*Power Gen Alternator
*Mallory Electronic Distributor
*Original 1938 Plates
This 38 Has A Lot Of Original Parts
*The Original Shocks, Rebuilt
*The Frame
*Front Axle
*Rear End
*Horns, And They Still Work!
*The Stock Speedo And Odometer Still Work
*The Odometer Is Showing 02913. So It May Have Turned Over, I Need To Have It
Checked. The Condition Of Car Was Almost A Museum Piece When I Got It, Just
Dusty and Neglected.
*Tailights Are Glass Repops, I Added The Right Side For Safety
*The Stock Gauges Are Still 6 Volt, They Did Work 3 Years Ago, Only Diconnected
Them
*The Old Mercury Filled Temp Gauge Does Not Work Was Rusted To Head
Had To Remove To Replace Head Gaskets.
*I Have Moon Gauges Under Dash For Temp, Fuel, Volts, And Tach.
*The Upholstery Is Velour That Looks Like Mohair, Has New Foam, Real Comfortable
*Most Of The Glass Has Been Replaced
*All The Window Regulators Still Work, Rear Windows Feature Full Up Then Keep
Cranking And Window Slides Back an Inch For Venting
*Paint Is Not Perfect But Is Still A 3 Footer, Meaning Little Scratches And Touch Ups
*Gas Tank Is Original! Replaced Cork Pads And Sending Unit, Stainless Bob Drake,
Was Really Nothing Too Clean Out When I Got It, But Just Cautious Because Of
Exterior Surface Rust. Sanded, Repainted
* New Gas Tank Filler Hose, Grommet, And V8 Cap
* Every Single Bulb Has Been Replaced And Works, Inside / Out
* Has So Cal Speed Shop Column Mount Blinker Assy (Need To Finish Wiring For That)
* New Glove Box Installed, Original Was Still Inside When I Got Car. Just Fell Apart
When I Started Using It.
* I do have Some of the original parts that were replaced. Such as a
6 Volt Gen, Fuse Assy, Air Filter, Breather, Radiator Supports,
Stock 39 Brake Master Cyl (needs rebuilt) plus other parts that will go with
car if buyer wants them
