1938 ford transmission fluid
RTWCO,
85/140 from a reputable source. Take your car out on a hot day and
drive it hard for 30 miles or so then check what the oil looks like....600 or 85/140
will be like kerosene when you drain it out. It's the additives in the 85/140 that
keep them going. Syncros hate 600.
Charlie ny
I researched the old 600W awhile ago, Ford called it 600W back in the model A days, I think it was made by Standard (Mobile oil) but it was a brand name, not actually 600 weight gear oil. I was led to LUBRIPLATE Lubricants Company, their SPO series gear oils are the best you can get to match the older gear sets. Their 600W (SPO 299) I think,is actually 250 weight, I put it in my rear end, transmission, & steering boxes. No leakage! Use JD cornhead grease for your U joint, it's 0 (zero) weight.
