I was attempting to post images in this thread. To cover up my ineptness, since I know how to edit, but not delete, here are my gear head stats on my V860 coupe:
Standard Coupe
Model: 82A-770A
Weight 2,354,
WB: 112 in.
Original Price: 595
Number Produced: 13,712
1938 V8-60hp
L-head
Displacement: 136
Bore 2.60 x 3.20
Stroke 3.2
Maximum brake horsepower 60 @ 3500 rpm
Torque ft lbs: 94 lbs @ 2500 rpm.
Compression 6.6
Compression at cranking 105
Iron block, Aluminum heads
Transmission gear ratios:
1st gear = 3.070
2nd gear = 1.83
third 1.0
Reverse = 4.015
Lub Capacity 1.75
Rear axle:
Gear ratio 4.44
Teeth pinion 9
Teeth gear 40
