1938 Ford tudor sedan. I am missing something on my hood prop, the lower hole in the hood prop assembly that lines up with the cowl pinch flange with a shouldered bolt has a large hole the size of dime, the bolt is 1/4", shoulder is 5/16 on bolt. Is there some type of special washer-bushing, guide?? that fills hole, mine is very loose on shouldered bolt. Upper mount on hood is correct and ok. John
