1938 fan shroud
Vintage Air makes an ABS plastic one but the fit description reads 1937, 38, 39 standard. Now a 39 standard would be like a 38 Deluxe so I figured it might be worth a mention.
I have made a lot of fairings for the helicopters from fiberglass over the years. I use foam as a make up buck since it can be removed after forming. Fiberglass isn't my favorite material to work with but it can be made to work with minimal cost.
I have yet to make one for my '38 deluxe but here are some pictures FlatheadTed shared with me of one he made for his('36 if I remember correctly).
468885
468886
468887
some more
"r'wrench" .....When you do a mod like that on a guy's helicopter, do you have to submit some sort of "STC"-type of paperwork, or are the fairings you mention part of an existing "STC" ....maybe an STC that you own? Just curious! DD
468885
Will .....My question is: Is that a '36 PICK-UP, rather than a '36 CAR? If so, like-year pick-ups have way more room because the radiator doesn't lean-back in a pick-up near as much as the CAR radiator. Dick D
