Jacques1960
Does anyone have the shop manual table showing alignment specs ? Thank you
What's a "frame to spring piece"?If you havent changed the front spring or inserted the very important frame to spring piece backwards (its tapered and sets your caster ) only bending will help like v-8 coopman said .
Yes, V8, inquiring minds want to know.
Which makes me wonder; How do you set or adjust the caster on a 40 Ford. I have been told the stock axle is straight with no built in castor and that there is no 'front" and "backside" for the solid axle
Although, you often hear the castor is set by bending the axle.
I would think the vertical height of the wishbone "ball" from level ground would play a roll in castor adjustment because moving it up or down will effect king pin inclination.
Am I incorrect? Not trying to hijack this thread.
Perhaps "The Caster Is Set by...." is not the best choice of words. To make all of this perfectly clear, this Coopman probably SHOULD have said...."To RE-SET the Caster once you've run over a couple of curbs, you must BEND the AXLE."
You are correct Jim, in that there is no 'front or rear' to these Ford I-beam axles. The king pin angles are factory-forged at the appropriate angles so as to produce the factory-designed CASTER and CAMBER angles when properly fitted within the stock wishbone as an assembly. The ball at the rear of the wishbone is secured at a pre-determined height (and angle) when bolted into the factory-designed socket in the center crossmember so as to SET the CASTER angle from the factory. And since the king pin bores are straight up and down with reference to the vertical center line of the axle as viewed from the side, the CASTER angle will remain constant whether the axle is mounted one way, or the other.....note the drawing below! The CASTER angle WILL CHANGE minutely as the axle travels up and down (in an ARC, about the wishbone ball) from a static setting.
CAMBER angles are pre-determined by the forging and machining process, as the mounting of the axle within the wishbone will facilitate proper angles when mounted in the chassis. Again, sliding into curbs and BENDING the end of an axle will upset the original setting, requiring RE-BENDING back to the proper setting. So, the original settings are designed-into the axle/wishbone assembly.....as long as you don't ever whang the front end suspension components to the point of BENDING them initially.
As a side note, king pin lock bolt holes ARE NOT tapered, front to rear! DD
I can take a pic and have but Im too tech challenged to post but can email pics and in the past Jsery has posted for me .
The GREEN BIBLE and THE 1938-41 FORD & MERCURY PASSENGER & TRUCK Manual show la listing for "the wedge" as being used only in commercial and truck vehicles.
