1937pickup
Great work-you are an artist in metal fab. Someone should send you a v-12 for that car. Have you had any problems fabing parts due to Englands conversion to the metric system, LOL.
Time for an update. I haven't spent a huge amount of time on the zephyr lately, but what time I have spent has been taken up with the lead work and repairs to one of the rear inner arches.
All the welds on the panels I made and where the roof was joined back on were leaded in and filed back. Because I was only doing about 2 hours work each night and the fact that I had problems keeping the flash rusting at bay during the time between working on it I opted to spray the roof panel in zinc primer and to get the lead as close as possible and then skim fill with normal filler. Not the way I had planned or really wanted but I was ending up spending more time cleaning up the panels than I was putting on more lead. To be fair I haven't had to put much filler in so it's not so bad.
I think the main problem I had was that I wasn't getting rid of all the residue from the tinning flux properly and it was causing the flash rusting.
The panels that I put in are now pretty much leaded up and filled ready for a primer coat.
The rear arch is also coming on well, it's pretty much welded up and until my grinder cooked it's brushes tonight was well on the way to being cleaned up as well.
Paul
