1937 Tudor door seals
Zeke...PA
Am I correct in assuming there is no seal along rear edge of door at B pillar ? It looks like a seal at the top from top of hinge to B pillar along top edge of body. As always thanks in advance, Zeke
It probably is the same 37-40 I would think. BD shows it as running along roof edge in his catalog. Is that the only place along with the hinge edge seal ? There are two rubber bumpers at the body B Pillar, is that all ? Zeke
Real men drive cars with no door seals, You are correct the top door seal runs from the upper front hinge across the top and stops at the B pillar , there is no vertical seal on the B pillar just two door bumpers. The air seal for the car door is the windlace on the interior side of the B pillar.
I ran Mac's seals from front bottom of door to the B pillar. Door originally had a flat seal from top hinge to bottom of door. Perhaps one of the earlier or later seals will fit the door. However the top seal will work fine along the hinge area. Be prepared to adjust the door latch and use 3M adhesive to secure.
