I see you guys are still on this, I still think its out of time some how. Now before you take a bunch of stuff apart and make a mess, it is easy to check to eliminate the stripped cam gear tooth issue.
Again remove all the spark plugs and slowly rotate the engine so that it is on number one Compression Stroke. Put your finger over the #1 plug hole so you can feel the compression build up as the piston reaches TDC, you can check that by looking in the cylinder and seeing that both valves are closed as you rotate the engine over on the compression stroke, if you pass TDC and you see the exhaust valve open, this means you have gone way too far past TDC.
Backyard mechanics says when you feel the compression pressure stop build up thats close to TDC with no measuring tools. Now you may be able to angle a 1/16" gas welding rod thru the spark plug hole to touch the piston to determine the top of the stroke but it is a tight squeeze. Any way pop off the #1 terminal cap cover and the rotor should be pointing to the number one distributor contact, that's the top left port looking from the passenger side of the engine. Now compare the position of the rotor contact to the terminal contact. If your rotor points significantly above or below that contact then there is an issue. If it is close to pointing to the contacts it will run but poorly. To further check the cam gear position you can again maintain TDC on the piston and then remove the distributor body from the timing cover. In time, the slot in the cam for the distributor drive tang points to the 11'o clock position when viewed from the front, if it does then its pretty much ok, if the slot is in any other position then there is an issue. To check for a stripped tooth simply rotate the engine over another 360* spin and as the piston come up on TDC make sure that the timing slot points to 11 o'clock if it does then that eliminates the stripped tooth with out disassembly, if it doesn't then you will have to do some further investigation.
