After reading the excellent discussions about removing the original fuel tank, I have a question about a replacement. In a post dated 4-2-2016 Dennis(EV8G) included this statement:
"Just to make you aware should you decide (for some reason) to replace this tank, Bob Drake reproduction tanks for these years CAN NOT be installed the way the original was removed. The tanks are stamped too fat on the sides and WILL NOT slide far enough to one side to get the opposite flange up on top of the frame rail."
Thanks to him for that information. Is there a solution to this problem?
