1937 Ford V8 Engine
skip86
Grand Island
Fla.
Price
295.00
1937 Ford Flathead v8 engine,dissasembled,nice clean block,new cam bearings,fresh hone marks in cylinders,no visible cracks in block,1 main cap has a very small crack in no.2 main cap,this crack is on the bottom of the cap near a bolt hole,needs to be welded or replaced,once again this is the cap not the block,this engine comes with the following parts,crankshaft which has been turned and has a fresh gear on it,2 oilpans,1 used oilpump with pickup,this pump is clean,very useable,oilpump gears and gear cover plate,2 camshafts,1 new with a new gear on it,1 used with a gear on it,2 earlier cylinder heads(the type with the waterpump in the head)2 early waterpumps(good for core exchange)8 used pistons with rings on them,7 connecting rods,12 stock Ford mushroom end valves with guides and retainers,a brand new set of 8 aluminum 3 ring flattop pistons mfg. by sILV-O-lite mfg. these are .040 over and will not fit in this engine as this engine is .060 over,however they would make good trading material,the price on these pistons alone is over $300.00.lots of pictures are available by E-Mail.pickup only in Central Fla.cash only on pickup,i will not pack and ship this mess.all parts are good useable parts not rusty junk.Thanks
Do you still have this 1937 Ford V8 engine? If so, would you post good clear photos of it from many positions?
Do you know the history of this engine? Is it stuck, is it rusted? Is it a good candidate to rebuild?
Would you take the time and money to rebuild it? Be honest now... :)
Thank you.
