1937 Ford Speedo?
PeterC
Hi all - can you please confirm which speedo this is ... 1937 Ford? Deluxe? Standard? Other?
Thank you!
Thank you!
Good morning Peter, and Merry Christmas!
Your speedo is a '37 Standard. The picture below shows a '37 Deluxe, the difference being that the Deluxe has FOUR digits in the TRIP mileage window, whereas the Standard only has three digits. Dick D
Below is an actual Deluxe dash. Deluxe has the two vertical chrome strips, plus the BANJO wheel. Note FOUR digits!
The pic just below shows the actual dash in a '37 Standard. Note lack of vertical strips and THREE digit mileage window.
DD - Wow - amazing that Ford would go through the expense to have 2 near identical speedo's with the only difference being 1 digit on the trip portion!
Thanks for all the details.
HI Dave.
Ford did not produce a "Business Coupe" in 1937.
Only three coupe models available for 1937:
Club Coupe, DeLuxe Coupe and Standard Coupe.
Correct, there are no 37, 38 or 39 Ford Business Coupes.
I know that there was 1940 Business Coupe (with jump seats), which is called by some -- but not Ford-- an "Opera Coupe."
What years did Ford have an actual Business Coupe?
I believe that there was a business coupe in '41. There was a coupe with jump seats along with the sedan coupe with the full back seat.
