I want to use my original face.
Ted Pyke
715-359-8684
tpyke2@frontier.com
What can you use for antennae? Dennis Carpenter repro or do you need a special antennae for say a mid eighties Ford Am Fm in a 37 Ford. Will engine noise/static be impossible to eliminate? I am interested in doing this with a 37 Ford tuning head and keeping 6 volt positive ground.The easiest way to convert a '35-36-37, etc Ford radio to a later style, AM/FM etc. is to use the head in the dash as a remote operator for a modern radio. The modern radio will have to be the type with mechanical knobs in lieu of electronic knobs. The modern radio is mounted up under the dash in a location suitable for the cables to reach from the head to the radio box. Modify the radio shafts so the cables will attach then secure the cables to the radio box.... This might take a little fabrication work.
The old radio head will work just fine to control the new style radio.... I know several guys that have used this procedure to get an affordable radio for their car.
If you have a 12 volt system any older 12 volt radio with 1 knob for on, off, and volume and one knob for tuning will work. If it has push buttons for tuning also, it will work you just won' be using them. I like the 70s Ford radio's MarvWhat kind of radio do you mean
I think I will follow your advice and try to use a 1985 or 85 Ford Ranger AM/FMradio I have,it is one of the last with on/off and tuning knobs instead of buttons. This is for my 37 Ford that I have no desire to tune in to AM talk radio, I thought the other posting on the ww.turnswitch.com was an interesting website showing the 1935 Ford radio head converted to operate a small black box receiver,that was untill I contacted them. They no longer make a mechanical operated box but have to have your control head to remove cables,changing the channel changer and on /off volume to electric,this all starting at $700.00. Think for that I will stick to my portable boom box.The easiest way to convert a '35-36-37, etc Ford radio to a later style, AM/FM etc. is to use the head in the dash as a remote operator for a modern radio. The modern radio will have to be the type with mechanical knobs in lieu of electronic knobs. The modern radio is mounted up under the dash in a location suitable for the cables to reach from the head to the radio box. Modify the radio shafts so the cables will attach then secure the cables to the radio box.... This might take a little fabrication work.
