Seattledavid
Have a 1937 ford that won’t start so I removed the distributor and I think I found the problem. The wire that goes to the coil on the other end of the wire there is a carbon piece that makes contact with the rotor. I put a meter on continuity and put one lead on the end that attaches to the coil and the other lead on the carbon tip on the other end of the wire and I’m not getting continuity and I should be correct?? If that is correct not sure how to fix it because I don’t see any of the parts available.
Also the Vacuum piston is really worn down and not sure if they are available either.
Dave Goodwin
Dave Goodwin
