1937 Ford Coupe Project
Scottsman
Hartwell
Georgia
Price
14 to 20K
1937 Ford Coupe project. Need to move this old Ford, been working on it off and on for 10 years. Lots of parts. The frame it sits on is has a new dropped axle, spindles, steering arms, spring, shackles with modified radius rods with new chevy disc brakes. 8" Ford rear end on parallel leaf spring kit. New radiator for an LT1. LT1 engine and 700 4R transmission. Body had new floors, new firewall, new door bottoms inner and outer, new tail pan inner and outer. I have new cowl patch panels and lower quarter panels. Fenders, hood and side panels have the orange paint still on them and have been kept in the dry. Have a set of hidden hinges, bear claw latches and many miscellaneous parts. In addition I have an original frame that has been modified with a Mustang style front suspension and coil over rear with a rebuilt 350 and 350 turbo ****** and 8" Ford rear end. You can buy as much or as little as you wish within reason and the price will be reflected in your choices. I would also consider trades for a Tractor or whatever as long as it runs.
https://picasaweb.google.com/115166956432195566334/CARS
I would be interested in the extra frame with suspension and 350/350. Can I get more info, pics and prices.
Jorgensencarl@gmail.com
I apologize for not responding quicker. I don't check this site often. The frame is an original 35-40, all the same, with a mustang front end, power rack, coil over rear suspension, stock 350 that I was told has not been started since rebuild, turbo 350. It has a set of Foose wheels and good, look new, tires. I don't have photos as it is under cover and it's cold. If you want it I'll take $ 6,000.00 CASH. If you are really serious, I can get you some photos when the weather is fit.
