1937 Ford carburetor
cavecars
I have a 1937 Ford 85 hp with a Stromberg 48 carburetor which someone added along with what I am assuming is not original, a 1/2" carb to intake spacer with vacuum port. Since I do not need the vacuum port does anyone know if I can just remove the spacer or is it needed?
Does your '37 have a two-speed rear-end aka a Columbia Overdrive? If not, removing the spacer will not cause a problem....
the mounting studs will be long but they can also be changed. Many of the hardware stores carry the proper stud.
No two speed rear end. I have also noticed that some people place an extra tall spacer under the carb, is that for keeping the carb cool?
I pulled the carb, so I got a pic of the spacer.
After the war, Ford used this location for the vacuum for the wipers. I think the wiper works better getting vacuum at this location instead of between two intake ports.
