1937 engine into 1934 Coupe?
37slantback
I believe I have seen this covered somewhere but can't find a definitive answer.
What are the fitment issues with putting a 37 engine and transmission into a 34 coupe?
Thanks,
-Don
None if you use the original mounts front and back and pump in head.
If you use later pumps , you will need the $40 spacers on ebay and still use the 34 trans mount.
Thanks Brian,
Good news then. I am pulling my 37 engine out and am going to drop the pan to check things out. The 37 is almost all stripped down in preparation for some major work.
But, like a sick sumbitch, I have a 34 Coupe on its way that needs an engine and transmission.
