1937 door sill scuff plates
Dstoner
New member
Looking for advice on removing door scuff/sill plates on my 1937 ford Tudor sedan. I’ve pried on them and looked for fasteners that may be holding it in place. Is it necessary to remove the running boards to remove them or is there another trick? Thanks fellas
I just pried them out completely destroying them in the process. If there’s an easier way I surely don’t know what it is. Luckily I have a new set.
I think the running boards need to be removed so that the tabs along the bottom edge of the door sill can be released. Then remove the screws in the face of the sill and lift up to release it from the rolled strip of metal that is welded to the floor.
The running boards haven’t been on my car for many years, so I can’t remember how large the gap is between the boards and the door sill. I am glad to hear you already had a replacement pair on hand.
