First off, I am NEW.....I have a wiring dilema. I have a 1937 1 1/2 ton. The truck came with a 2 brush generator and a regulator on it. No breaker on the generator. I am replacing the wiring harness's on the truck. I ordered the correct harness for the motor that has the regulator. I ordered the correct harness for the 37 dash. Now....I have two issues to resolve. First...... the coil wire from the 37 dash harness should go direct to the coil, but the engine harness has its own wire that goes under the dash to the resistor. I am pretty sure I can just connect these two together under the dash. Correct me if that is wrong. Second.....the regulator has a tab labeled "bat" which the wiring diagram says should get a yellow wire from the dash harness. Obviously that isn't there, so can I just make a jumper from the yellow wire under the dash? There is a yellow/black wire that is available from the dash harness that would normally go to the breaker on the generator. Would that work as the yellow to the regulator "bat" terminal?
I can get pictures and diagrams if someone needs. Hoping someone with experience can clarify my issues.....
