M mindox Junior Member Apr 1, 2016 #1 City prescott State wi Hello I am in need of 34 washers that would be used between the aluminum heads & the nuts that hold the heads on. The washers are a bit thicker than normal grade 8 washers & the outside diameter of the 3/8" washer is smaller than normal, 3/4 " od.
