Seth Swoboda
Does anyone have a photo of the correct spark plug conduits for 1936?
Zeke3
1932's are NOT the same as 33-36's....32's are a one year only conduit. YES, 33-36's will work/fit 1932 BUT "technically" and "Concour's Correctness" - wise....NOPE, not the same.
Seth, the early conduits, have the long mounting arms, one easy way to tell. Seth, not sure IF these help and not sure on the minutest details (IF any) from 33-36 but its what I got for you.
Zeke3
I need to familiarize myself on the 37's BUT here is the later ones and the short mounting arms compared to the early ones, you can see the differenceI think these photos help. I appreciate the responses. I want to get the correct conduits on the engine.
Here on Ebay right now and a BIN for $49.99. Correct for 33-36 and cheap.The brass ferrules around the wire ports even look good.
https://www.ebay.com/itm/127858301804
Seth
Another set for $40 just up the road from you
https://www.ebay.com/itm/1985480714...3DTHfWBgmJE1daF53VPnKBF6tJ|tkp:Bk9SR-Sc3peUaA
Better set ,ready to install $110
https://www.ebay.com/itm/158289641021
Something is strange with the drivers side. Stay away.Even the pass side curve of the bend is not quite right
