1936 slant back parking light sockets.
lgndlt5
Trying to locate NOS or is used. Does anyone have a source or spares they might wish to part with? No aftermarket luck. Thanks. 847-275-4841.
You should put your ad in the swap section.Its in the discussion forum. Southside Obsolete in MN might be able to help you.
Mac's offers a turn signal conversion kit with wires. It says you must drill a hole in the reflector that's 3/4", but the 36 already has that hole...don't know its diameter, though. Terry
Look at Dorman they should have something you can make work. If you just need the cards and spring you can buy them . If you need the socket and all you can get those. May have to alter a tad.
